Can I add GSI coordinates into a Revit project?
1 REPLY 1
303 Views, 1 Reply
The university I work for just assigned a project where they want the existing 150+ BIM files in Revit 2014 to be updated to where the drawing where point True North, and where the GSI coordinates are put into place so that the Sun Trace is geographically correct. How do I go about doing this? The GSI coordinates, for example, are in the format of: (12792639.059 feet 289432.567 feet).
1 REPLY 1
BIMologist_
Check to see if this article can help you with your question.
http://www.aecbytes.com/tipsandtricks/2010/issue54-revit1.html
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
