The university I work for just assigned a project where they want the existing 150+ BIM files in Revit 2014 to be updated to where the drawing where point True North, and where the GSI coordinates are put into place so that the Sun Trace is geographically correct. How do I go about doing this? The GSI coordinates, for example, are in the format of: (12792639.059 feet 289432.567 feet).
Check to see if this article can help you with your question.
http://www.aecbytes.com/tipsandtricks/2010/issue54-revit1.html
