Can Autodesk Revit Export DWGs, that comply to layer standards, and how will exp
2 REPLIES 2
243 Views, 2 Replies
Can Autodesk Revit Export DWGs, that comply to layer standards, and how will exported sheets appear in AutoCAD?
2 REPLIES 2
Of course. Like AutoCAD drawings.. "Janice Guok" wrote in message news:28537746.1093339096571.JavaMail.jive@jiveforum1.autodesk.com... > Can Autodesk Revit Export DWGs, that comply to layer standards, and how will exported sheets appear in AutoCAD?
sbrown
There is a file under the file menu in revit calle import/export settings. you just set that up to your layer standards, then when you export it will place the lines on the proper layer. Revit defaults to the AIA standard and has a few other choices built in.
