As far as I can tell, there is no way to switch back and forth between perspective and orthographic projection on an existing camera, anyone have a solution?
Solved by lionel.kai. Go to Solution.
I don't know of any way of changing this. Any camera view you take is going to be perspecitve. any view from the default view will be ortho.
LD
This is an old thread, but maybe someone is still finding it while looking for the answer:
Make sure "Crop Region Visible" is checked, then right-click the View Cube and choose "Toggle to Perspective-3D View" (or choose "Toggle to Parallel-3D View" to go back).
Of course it's much easier now (in Revit 2019): just change the "Projection Mode" property (under the "Camera" group) to "Orthographic" or "Perspective".
