Lately the camera height has been moving on its own. I am very certail that the level and eye height are set correctlt. Then both the camera and the eye level change to -12 or -48 or some other odd number. Any idea what is happening here? It happens on several computers.
Nardo
Hi there,
I am not sure if I understand correctly but I perhaps my experience can point you into the right direction.
When placing a camera, I had a issue with the camera height giving me the strangest values instead of the standard 1750mm I know I should see.
I took forever to figure out, but I noticed it related to the view range of the plan I am taking the camera shot in.
If your cut height & top height is set to the same value the camera default camera height offset freaks out.
Check your view range & make sure your cut plane & top value aren’t set to the same height.
