Hello All,
Durning an online training segment, there is a learning section using callouts for floor plans. It's straight forward but when I make a callout on level 1 for an enlarged floor plan, the view is created in "details views - Detail 0 and not "floor plan view - callout for level 1". Is this something to do with the template? How do I change or fix it.
Thanks in advanced
Jeff (novice)
Solved by Jleibold. Go to Solution.
Solved by loboarch. Go to Solution.
Thanks....duh...I now remember the type selector options....
I had the project browers & properties windows set up to tab between the menus & not the properties over the project browser...
Again, thank you....
Jeff
