I have created a operable window to insert in a curtain wall system based on the "Window - Curtain Wall" family. I created a simple extrusion for the glazing panel and assigned it the subcategory of "Glass". When loaded in the project, the cut lines of this panel are a much heavier weight than mullions, other glass panels, etc. The lines are so thick, the double line just becomes a fat single line as they merge together. Adjacent glass panels don't have this line weight problem. I can find no override or other control/parameter that fixes this. Input is appreciated.
Did you look in Object Styles under Visibility/Graphics? You should be able to set the line weight there.
See attached.
cheers
