Building_Design_Suite_Premium_2015 difficulties specifically with Revit.
The problem is to save the files, insert CAD, sync and recharge the Central Archive, we are sending a fatal error and closes the program. We have already installed all the updates and the problem persists.
We appreciate the support that we can provide on topic.
Solved by David_Knight. Go to Solution.
this looks like a corrupt revit file.
have you tried restoring a backup?
i had this problem, my file was corrupted. autodesk was able to recover it for me (there are no guarantees). our backups had become corrupted too.
this is how you submit a case for autodesk support for a corrupted revit file.
