At Home>Opening tab>Wall in Revit 2012 I cut an opening in a brick rainscreen wall and the brick coursing turned vertical at the wraps. Does anyone know why this happened or have a solution?
In case anyone else runs into this, I discovered the solution. I used Home>Opening>Wall to create the openings that caused the vertical brick. When I deleted this and used Edit Profile the problem was solved and the brick is now wrapping as one would expect.
