Break Lines not hiding in RCP
7 REPLIES 7
Message 1 of 8
josh
6665 Views, 7 Replies
I am using the default Revit break lines in a few of my plans, and they work great. But when I insert them into an RCP, the masking regoin does not mask anything. Tried send to front/back, copying, inserting new. My other masking regions will still work as they are supposed to, but this break line does not.
Any suggestions would be helpful.
7 REPLIES 7
Message 2 of 8
josh
in reply to: josh
A quick work-around is to create a masking region and break line seperately that mimic the actual thing. But I am still looking for an explanation as to why it won't work if anyone has any ideas.
Message 3 of 8
alan.quinn
in reply to: josh
I cannot re-create the issue. Look at Level 1 RCP in the attached file. If you are still seeing the same issue please produce a similar sample file and attach.
Thanks for posting.
Message 4 of 8
rosskirby
in reply to: josh
Make sure that view isn't set to wireframe.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Message 5 of 8
josh
in reply to: rosskirby
This was it, simple solution. I have found the Roof Framing Plans look more the way I like them and are easier to control as wireframe RCPs.
Message 6 of 8
rosskirby
in reply to: josh
Simple solutions are the best kind.  Smiley Happy  Glad I could help.
If you find yourself working in wireframe a lot, it might be useful to set up two separate views, one that goes on the sheet, and one that you work in (i.e annotation views and working views, respectively).  That way you don't have to worry about something looking wonky when you go to issue drawings.  We have all of our views set up that way (except drafting views, legends, etc., of course), along with a separate presentation set of views.  Each has their own view template to control what is/isn't visible, v/g overrides, filters, etc.   A little more complicated to set up and get used to, but ultimately more productive and efficient in the long run.
Good luck to you.
Ross Kirby
Principal
Dynamik Design
Message 7 of 8
rosalva.cutino
The break line doesn't show the mask region
Message 8 of 8
genius.
