Boot Camp with Windows 7, REVIT freezes after a couple minutes, HELP
8 REPLIES 8
Message 1 of 9
1692 Views, 8 Replies
I have Windows 7 installed on my MacBook Pro with Retina Display installed with Boot Camp. I have AutoCAD 2012, 3DS Max 2013 and Revit 2013 installed. However, Everytime I open up Revit, it freezes within a couple minutes. WHY?
8 REPLIES 8
Message 2 of 9
I'm having the same problem with Revit.
Message 3 of 9
I am experiencing the same problem with the same running set-up (macbook pro with retina, windows 7)... Any sugggestions out there?
Message 4 of 9
I've solved the issue. Revit 2014 is working perfectly on Windows 8 using bootcamp.
Message 5 of 9
Hi Christopher,
do I understand it correctly, that there are no problems using MacBook Pro with Retina display under Bootcamp/Windows 8 with Revit 2014??
Mike
Message 6 of 9
I also have the same problem
seems like youve solve the problem
could you please tell me how to make
revit to run properly
running on mac book pro 15 retina display bootcamp
windows 8
thank you for your time
sincerely,
Justin Moon
Message 7 of 9
dandantodd
I have a MacBook Pro 15" Retina Display and I'm running Boot Camp with Windows 8, but Revit is flickering uncontrollably and I cannot use the properties bar or the ribbon without hovering over it. Have you resolved the issue?
Message 8 of 9
rosskirby
in reply to: dandantodd
Any time something flickers or doesn't display properly (i.e. jumps around on the screen, or is transparent when it shouldn't be, etc.), I immediately suspect the video card.  Can you post which video card is installed on your machine, and whether or not its drivers are up to date?
Also, what version of .NET is your Windows partition running?  I've seen that affect the ribbon, but it could conceivable affect other toolbars as well.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Message 9 of 9
BIMgirl
did you check this out?
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Cheers!
Lejla Secerbegovic - Architect and Revit Expert
http://bim-me-up.com
