Can someone please explain to me what it means by "Core Boundary - Layers above Wrap" and how it relates to the material in between this wrap being the structural material? I have to model a building's shell as close to the actual as possible to have as accurate as possible a heating and cooling loads analysis/ energy simulation, so I kind of would like to understand what it all means....if possible
Solved by constantin.stroescu. Go to Solution.
there are many materials about this subject....
Try some of the list below:
http://www.revitzone.com/3d-modelling/58-walls-a-basic-introduction
http://reviting.net/tutorials/extending-walls-wall-layers-revit
http://www.revitzone.com/3d-modelling/161-walls-applying-functions-to-compound-layers
http://www.cadlinecommunity.co.uk/Blogs/Blog.aspx?ScoId=62281e36-7305-4dc9-86ff-d6abb27c727c
wish you good look!
Constantin
Constantin Stroescu
