Revit Architecture
Member
PSBrown
Message 1 of 3 (840 Views)
Base Extension Property
840 Views, 2 Replies
08-22-2012 09:50 AM
On a simple exterior wood frame wall type, I can't seem to figure out how to activate the base extension property; it is greyed out. How do I activate this parameter so I can extend the exterior sheathing of the wall past (below) the rim joist?
Employee
loboarch
Message 2 of 3 (828 Views)
Re: Base Extension Property
08-22-2012 11:36 AM in reply to: PSBrown
You need to unloack the layers of the wall you wan tto extend.  In the type properties dialog, edit the structure of the wall.  Click "Modify" in the lower section of the editing dialog.  Then you can click on the edge in the wall preview and "unlock" the wall layers.  Once you do this the base extension property for the wall will no longer be gray.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Member
PSBrown
Message 3 of 3 (812 Views)
08-22-2012 02:44 PM in reply to: loboarch
Thanks Jeff. Much help. Now I have a similar question with a roof. I'll post a new thread.
PB
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
