Hi all,
Anyone know if you can set a directory for backups of project files / families? These files # # # #. # # #. Rvt or # # # #. # # #. Rfa
greetings
Solved by loboarch. Go to Solution.
They are placed in teh same folder as the main Revit project file. There is no user setting to change this location from within Revit. It would not be too hard to write a batch file to periodically check a directory for the backup files and move them automatically.
Yes, I've used it for some time but, with network addresses (UNC) that operation escapes my knowledge. I've been trying it.
Thanks, is there any other idea?
