Revit Architecture
Active Member
Mohab3
Message 11 of 24 (639 Views)
Re: Autodesk Revit Architecture 2012 is now available
11-16-2011 03:58 PM in reply to: slatch
i need the "Tianjin Cruise Terminal" revit file for education purposes which is the building on the cover of the 2012 revit Architecture, any help would be appriciated
thanks in advance
Member
justtonis
Message 12 of 24 (597 Views)
12-09-2011 12:25 PM in reply to: Mohab3
hi.
i have Revit Architecture 2012 installed. The problem - can not install Update 1 or Update 2, because as the error message says: "...the expected Autodesk product could not be located on your computer. Make sure that you are using the correct Update Release for the product."
I am sure I am using the correct update release. How can I make Update locate my Revit???
thanks in advance
*Expert Elite*
DarrenP
Message 13 of 24 (595 Views)
12-09-2011 12:26 PM in reply to: justtonis
are you installing the right revit update?
there are 3 revit products
and also consider 32 bit & 64 bit version
Member
justtonis
Message 14 of 24 (585 Views)
12-09-2011 02:52 PM in reply to: Mohab3
sure, I have Revit Architecture 2012 (32-bit) and using student licence
And the update is "Autodesk_Revit_Architecture_2012-x64_Update", it's said that it is suitable for 32bit.
*Expert Elite*
DarrenP
Message 15 of 24 (581 Views)
12-09-2011 03:20 PM in reply to: justtonis
thats the wrong update you need to installl the 32 bit version
Member
justtonis
Message 16 of 24 (565 Views)
12-11-2011 07:45 AM in reply to: DarrenP
look, i found it here: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=16841348
and it's written :
Autodesk_Revit_Architecture_2012-x64_Update 1.EXE
(or Autodesk_Revit_Architecture_2012-x86_Update 1.EXE for RAC2012-32bit)
there are no other updates, are there??
i just need to install it, because my revit crashes everytime I try to do something with materials...
it's not possible to work on these conditions.
please, help me somehow.
thanks,
Member
justtonis
Message 17 of 24 (563 Views)
12-11-2011 07:50 AM in reply to: justtonis
God, I am so stupid. it's written, that 86 update is for 32 bit Revit :smileyvery-happy:DD
i'll try it and let you know.
New Member
arc90150
Message 18 of 24 (495 Views)
01-16-2012 07:50 AM in reply to: acardoso
Hi Acardoso, I have the same problem as Pedro - I can't find the families + there isn't a default template to load when I start the program. Could you explain in more detail how to fix this ? I am using Windows XP SP2. Grigor
Active Contributor
Message 19 of 24 (422 Views)
02-19-2012 08:25 PM in reply to: pedroaroso
Yeah I agree with you man we were bringing up this issue all the time with ADT/ACA & here they are doing it again to the"new" baby.
sportyhd
New Member
Message 20 of 24 (332 Views)
03-26-2012 05:14 PM in reply to: slatch
I have just installed it but when I start drawing it keeps gining me the same error: An error has occurred while drawing the contents of this window. This window shall be closed.
Please help me how can I fix it????
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
