Revit Architecture
Message 1 of 5 (181 Views)
Attach wall to underside of Stair
181 Views, 4 Replies
05-13-2004 05:10 AM
Hi, is it possible to attach a wall to the underside of a stair? If so, how would you recommend doing this?
The normal "Attach" doesn't seem to work for me.
*v.valentijn
Message 2 of 5 (181 Views)
Re: Attach wall to underside of Stair
05-13-2004 08:09 AM in reply to: gmak
The answer has been posted before at zoog's.. for future reference, search this newsgroup and/or AUGI For your comfort: You can draw a RefPlane on the underside of the stairs [in section] then attach wall to this instead of the stairs itself. The other alternative is to manually modify the wall's boundaries [sounds more difficult than it is in practice].. good luck :smileywink: "gmak" schreef in bericht news:29085840.1084450273262.JavaMail.jive@jiveforum2... > Hi, is it possible to attach a wall to the underside of a stair? If so, how would you recommend doing this? > > The normal "Attach" doesn't seem to work for me.
*Scott Davis
Message 3 of 5 (181 Views)
05-13-2004 08:10 AM in reply to: gmak
Go to an elevation which shows the side of the stair. Create a Ref Plane, using the Pick tool, aligned to the edge of the stair/stringer you want the wall attached to. Now, highlight the wall, click the Attach button in the Options bar, and then select the Ref plane to attach to. If you lock the Ref plane to the Stair, and then the wall is attached to the Ref plane, if the stair changes, the wall will change too. SD "gmak" wrote in message news:29085840.1084450273262.JavaMail.jive@jiveforum2... > Hi, is it possible to attach a wall to the underside of a stair? If so, how would you recommend doing this? > > The normal "Attach" doesn't seem to work for me.
*Bree Day Partnership
Message 4 of 5 (181 Views)
05-13-2004 09:47 AM in reply to: gmak
Thanks "V" and Scott, that's helped me too on a very similar problem. Damian "v.valentijn" wrote in message news:40a38fa7_3@newsprd01... > The answer has been posted before at zoog's.. for future reference, search > this newsgroup and/or AUGI > > For your comfort: > You can draw a RefPlane on the underside of the stairs [in section] then > attach wall to this instead of the stairs itself. The other alternative is > to manually modify the wall's boundaries [sounds more difficult than it is > in practice].. good luck :smileywink: > > "gmak" schreef in bericht > news:29085840.1084450273262.JavaMail.jive@jiveforum2... > > Hi, is it possible to attach a wall to the underside of a stair? If so, > how would you recommend doing this? > > > > The normal "Attach" doesn't seem to work for me. > >
*Arfath
Message 5 of 5 (181 Views)
05-31-2004 09:22 PM in reply to: gmak
Hi, This was really excellent solution. I had been working on this since last 2 days but could not think much. Thanks once again. But I am afraid if the user have folding stair, where he sees the stepper underside not linear. Keep thinking.... "Scott Davis" wrote in message news:40a38f74$1_1@newsprd01... > Go to an elevation which shows the side of the stair. Create a Ref Plane, > using the Pick tool, aligned to the edge of the stair/stringer you want the > wall attached to. Now, highlight the wall, click the Attach button in the > Options bar, and then select the Ref plane to attach to. > > If you lock the Ref plane to the Stair, and then the wall is attached to the > Ref plane, if the stair changes, the wall will change too. > > SD > > "gmak" wrote in message > news:29085840.1084450273262.JavaMail.jive@jiveforum2... > > Hi, is it possible to attach a wall to the underside of a stair? If so, > how would you recommend doing this? > > > > The normal "Attach" doesn't seem to work for me. > >
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
