In starting a new project, I renamed "Level 1" to "Street Level" and "Level 2" to "Level 1". Next I added two additional levels in the drawing, "Level 2" and "Level 3". My Project Browser shows only Level 1, Site, and Street. Why do the Levels 2 and 3 not show under and how can I get them to.
Solved by damo3. Go to Solution.
You have created "black" levels instead of "blue levels" to make levels you have created show up in the project browser
Go to VIEW ribbon
>on the CREATE panel look for PLAN VIEWS, click and select floor plans. Ensure "do not duplicate existing views' is ticked and select the levels you wish to make plan views of.
for future levels to show up in the browser without this process, tick the check box plan view in the options bar when making the level.
hope it helps.
In my case the level was listed in the browser. it was already on a sheet and now is not. It is a blue level as indicated on the elevations. Clicking on the blue level circle takes me to the floor plan view. I am trying to drop it back on it's sheet but can't find it in the project browser to drag it on the sheet.
I need some quick direction as I am on a very tight deadline.
Thank you,
Gil
