Revit Architecture
*Expert Elite*
doni49
Message 1 of 5 (527 Views)
Asphalt Shingles Require "Realistic", B&B Wall Pattern requires "Shaded"
527 Views, 4 Replies
06-07-2013 11:33 AM
I created a Board and Batten material using a pattern I downloaded from this forum (http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Board-Batten-Exterior-Finish/m-p/2514833#M...).
The wall looks great when viewed in "Shaded".  But when viewed in "Realistic", the B&B pattern disappears and is replaced by solid color.
I used the OOTB Asphal Shingles on my roof.  If my view is set to "Shaded", they do not show -- all I get is solid gray.  If I change the view to realistic, I get the roof shingles.
I'm currently at a loss here.  Any ideas?
I'm attaching a screen shot of what the two look like.
Thanks!
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
mpwuzhere
Message 2 of 5 (517 Views)
Re: Asphalt Shingles Require "Realistic", B&B Wall Pattern require
06-07-2013 11:55 AM in reply to: doni49
Realistic utilizes an actual image map of what the material looks like....so if you don't have an image assigned it shows as a solid color.  Be aware that any 3D Fill Patterns assigned to a material will not show up in Realistic either.
*Expert Elite*
doni49
Message 3 of 5 (515 Views)
06-07-2013 11:58 AM in reply to: mpwuzhere
Thinking that it might be something along those lines, I downloaded an asphalt shingle pattern file (http://www.revitcity.com/downloads.php?action=view&object_id=3012) and assigned it to the roof as well.  I thought maybe the pattern would show up when in shaded.  But it didn't appear.
Don Ireland
Forum links:
Civil 3D General
mpwuzhere
Message 4 of 5 (507 Views)
06-07-2013 12:26 PM in reply to: doni49
Was it Model or Drafting Pattern?  Drafting Patterns only show in 2D....Model in both 2D and 3D....
*Expert Elite*
doni49
Message 5 of 5 (504 Views)
06-07-2013 12:36 PM in reply to: doni49
Model
Don Ireland
Forum links:
Civil 3D General
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
