Hi all
I'm having a problem with the attached family. I create an array where the number of legs change according to the length of the bench. But I need to give the bench different heigths and here is where the height of the legs don't work. thanks for any advise. please see attache file.
I think you will get better results by creating a separate nested family out of the legs, assigning a Shared Parameter for the Height and loading that into your bench family. Then add the Height parameter.
Hope this helps and thanks for posting.
