Revit Architecture
Active Contributor
mthemelis
Message 1 of 3 (105 Views)
Arc walls
105 Views, 2 Replies
08-16-2004 01:29 PM
I want to create an arc wall that starts with 12 meters heght and ends with a height of 8 meters.
How is it possible to create something like that?
*Aaron Rumple
Message 2 of 3 (105 Views)
Re: Arc walls
08-16-2004 02:18 PM in reply to: mthemelis
Draw the wall in plan. Go to the elevation and draw a slopping ref. plane from one end of the wall to the other. Select the wall. Use Top/Bottom - Attach - Pic the Ref. Plane. You can move and rotate the ref plane later to modify the slope. "mthemelis" wrote in message news:33359346.1092688217055.JavaMail.jive@jiveforum2.autodesk.com... > I want to create an arc wall that starts with 12 meters heght and ends with a height of 8 meters. > How is it possible to create something like that?
Active Contributor
mthemelis
Message 3 of 3 (105 Views)
Re: Arc walls
08-18-2004 10:58 AM in reply to: mthemelis
Ok thank you!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
