Arc Aligned Text in revit
6 REPLIES 6
shiraz.ansari
12892 Views, 6 Replies
Is it possible to create Arc Aligned Text in Revit? as in Autocad
6 REPLIES 6
LisaDrago
in reply to: shiraz.ansari
Not that I know of at this time.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Alfredo_Medina
in reply to: LisaDrago
Revit does not have a tool to do that. At least not as simple text or annotation. But if you really have to do it, even though it is a model, you could host a model text family with one letter at points that are hosted on a spline, in the generic adaptive template. You could load it in a project, but not into other types of families.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Chris_Baze
in reply to: Alfredo_Medina
Alfredo, is this still the best method for text along an arc in Revit 2015? I plan on using this method to create a family for a digital architect's stamp.
doakdesign
There are two other workarounds you could try:
1: create a single character of text, then do a radial array of that as needed to get the orientation you need (be sure you deselect the check-box "Keep readable", otherwise this method breaks down when you need the text to span from the upper to lower half of the arc, as the lower half text will rotate out of position from the upper. Before doing the array you'll need to get a rough idea of how many characters you have, and about the angular distance the text will span so you can do the math on how many degrees to array the first text.
2: create the text you need in autoCAD using the arc function (can't remember exactly how to do it, haven't done it in years), then import into Revit.
scenesketcher
Ten years later - still no tool to label along paths. Would be very useful for site plan road and
water ways.
in reply to: scenesketcher
You can host an adaptive family with instance text parameter on a divided spline.
