Revit Architecture
Valued Contributor
RaoulTittel
Message 1 of 3 (155 Views)
Accepted Solution
Application tab in revit changed my tab layout
155 Views, 2 Replies
11-10-2013 05:02 PM
I installed an application into revit 2012, now it has shoved itself up to the left most tab and is interfering with my workflow.
Can I change the tab position on the ribbon so the application tab is always far right?
Cheers,
Raoul
Using Revit 2012
Valued Mentor
AJA14
Message 2 of 3 (129 Views)
Re: Application tab in revit changed my tab layout
11-10-2013 09:07 PM in reply to: RaoulTittel
Any tab can be moved by clicking control and dragging the tab.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Valued Contributor
RaoulTittel
Message 3 of 3 (123 Views)
11-10-2013 10:59 PM in reply to: AJA14
Hi Ali,
Ahhhhhh, thanks for that .
Raoul
Using Revit 2012
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
