Annotations- Auto stacking
3 REPLIES 3
vdes
1469 Views, 3 Replies
While annotation in Revit Architecture how to enable autostack dimentions for fractional dimentions such as 1/2"  ...pls finf the attached file as done in Autocad ..my question is how does one achieve the same in Revit Arch???
Pls help
3 REPLIES 3
loboarch
in reply to: vdes
There is no option for autostacking fractions in Revit.  The only way you could do that kind of thing would be to manually place text and use a stacked fraction if the font sytle has special characters defined for them.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
vdes
in reply to: loboarch
Thanks for your post.
Pls find the attached file in the Annotation style parameter & guide me where to change the font style for stacked fraction...
loboarch
in reply to: vdes
Maybe you mis-understood.  There is not a way to stack fractions directly/automatically in Revit.  There is not a "setting" that will allow it.  The only way to do it is by entering text manually and then use the "charmap" tool in Windows to find the correct character code to "place" a stacked fraction character in your text note.  This assumes the font you are using has stacked fractions in the special character set.
Jeff Hanson
Revit Help |
