Is there an easy way to have annotation such as room names and apartment numbers automatically appear in other plans such as the ceiling? I have set up my reflected ceiling plans to use the floor plans as an underlay but the annotation does not come through.
Thanks in advance.
N.
Solved by Alisder.Brown. Go to Solution.
Thanks maciej,
When I copy from the floor plan to the ceiling plan the text appears in a different place. What's the procedure to make sure the text ends up in the same place on both plans?
Hello maciej,
I select the text, hit ctrl+C, go to the ceiling plan, hit ctrl+v, the text appears in blue. I hit enter and the text disappears.
What am I doing wrong?
I thought it might have been hidden by the ceiling grid, so I deleted the ceiling grid, but it still is not showing.
Dont use the Ctrl+V option to paste in Revit. And you shouldn't be pressing Enter either.
Select all the annotation you want from the plan view, Click on the "copy to clipboard" button in the Clipboard panel in the ribbon, the hit the dropdown arrow under Paste, and choose any of these 3 options "align to selected views" (Allows you to do multiple views), "Align to current View" and "Align to same place"
This should work for all annotation that is not being pasted outside its host
Hope this helps
Hi Alisder,
Thanks for your prompt reply. Paste to Same Place worked fine.
