Revit Architecture
Member
info
Message 1 of 7 (1,853 Views)
An error has occurred while drawing the contents of this window
1853 Views, 6 Replies
09-22-2011 08:01 AM
After using the program for a few weeks it appeared the error message "An error has occurred while drawingthe contents of this window" only when I open the 3D view. I reset the Windows user profile and everything is back to normal operation. Today has come out again this error screen. Video drivers are certified and the board is a Nvidea Quadro and normally I have no problems. To test I created a new user and everything works fine.What could alter the software related to user profile? Thk!
Product Support
Chris.Aquino
Message 2 of 7 (1,835 Views)
Re: An error has occurred while drawing the contents of this window
09-22-2011 03:39 PM in reply to: info
If you have not already, I would try disabling (or enabling, if already disabled) Hardware Acceleration in the Revit Options.
I would also try clearing out the Temp folder on the machine. You can do this by hitting Windows+R, entering %temp%, then clearing out as many files as you can.
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
Member
info
Message 3 of 7 (1,826 Views)
09-22-2011 11:54 PM in reply to: Chris.Aquino
If I disable the hardware acceleration works but is not the solution, we work with very large projects and we have to use the video card acceleration. I have tried deleting temp files but does not work. thanks
Member
info
Message 4 of 7 (1,797 Views)
09-26-2011 03:16 AM in reply to: info
anyone can help me?
Member
info
Message 5 of 7 (1,795 Views)
09-26-2011 03:36 AM in reply to: info
I have seen that the error occurs simply by clicking a family because it can not display the graphic in the upper left "property" with the type of item eg. wall.
Thk.
New Member
sadhumon916
Message 6 of 7 (1,176 Views)
12-01-2012 12:05 AM in reply to: info
anyone can help me?????????? plzzzzzz....
Member
Rustle
Message 7 of 7 (1,100 Views)
01-09-2013 05:35 PM in reply to: sadhumon916
I am having this problem too.  Only one user has the problem.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
