An error happened when Install Revit 2014
2 REPLIES 2
wjxu55
490 Views, 2 Replies
An error happened when Install Revit 2014.  how to fix it? See attached picture. Thank you!
Willie
2 REPLIES 2
TravisNave
in reply to: wjxu55
I see this one come up a lot.  I recommend that you start here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15149656&linkID=9240697
There's a bunch of other resources on this, including some of my own here:
http://usa.autodesk.com/adsk/servlet/u/bsearch/results?siteID=123112&catID=18297903&qt=faro.ls&bh_qt...
I haven't written anything official myself, by perhaps I should.  Smiley Very Happy
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
wjxu55
in reply to: TravisNave
Thanks so much!
