Adjusting Line weights
0 REPLIES 0
Message 1 of 1
323 Views, 0 Replies
I have adjusted ALL my line weights in Object Styles using only pens 1,2, or 3.. and the cut lines still look heavey on cut sections, (compared to what I'm used to with AutoCad). Do any of you find that you have to go and change the actual lines weights themselve vs. just changing the "pen" number to get a traditional pen 1-5 line weight? And yes I know this questions dates me - I learned on plotters that used real pens, which I think were something like .05 mm to .15 mm?? or something like that.
I should add that I work mostly at home (in AutoCad) and rarely get to see full scale plots of my work, which makes it difficult to know if there are graphic issues with the final product - and becuase I work mostly with home owners and contractors, my clients are not very sophisticated about such matters. That being said, it still seems like the line weights in Revit are very heavy compared to what I'm used to in AutoCad.
0 REPLIES 0
