hi
I tried to Drafting Pattern aligned with my two But it is very difficult .
Is there a quick and accurate way to solve this problem
Attache Revit File(Saved 2014)
Replace your drafting pattern type with a model one. Draw your filled region and mirror.
hi
Yes .I know.
But I'm trying to Drafting Patterns I use.
Thank you for the reply.
You cannot change the origin point of a Drafting Pattern as it is based on the internal origin of the Project file, therefore you cannot simply adjust the lines of the hatch. I don't think Drafting Patterns are really intended to be used that precisely. I understand that doesn't look very professional, so is there any specific reason why you cannot use a Model Pattern?
