Add parameters to model in place; possible??
2 REPLIES 2
2740 Views, 2 Replies
I want to see if it is even possible to add paramenters to a model in place casework?
Does anyone know?
Thanks.
2 REPLIES 2
cbcarch
I think not.
However, you might be able to do this:
http://whatrevitwants.blogspot.com/2011/07/save-in-place-family-as-rfa-for-use-in.html
Then add parameters, save, load back into your project.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Alfredo_Medina
Yes, any object created as model in-place can have parameters and other features available in the family editor. Notice that when you start a model in-place, you have the same tools available on the ribbon: family types, reference lines, reference planes, etc. They are available until you finish or cancel the model in-place. The only difference is that at the end you have created a family for this project, not a file with .rfa extension that can be used in other projects, which is why we prefer to do families in the family editor.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
