I am working on an NPS project in Revit and concerned about the final deliverable with the strict NPS standard. Although you post is old, I would like to know how it turned out with a Revit project going to the National Park Service.
thanks,
Did you find a reasonable solution to using Revit on a NPS project? We are in the same position and I would like to hear about your experiences.
Thanks, Boyd
The firm I work for is running across the same issue with projects for the Corps of Engineering. We have utilized Revit and AutoCAD for many years now, but when we prepare the Revit files to deliver to the Corps, we have not found a way to get the layer naming convention provided by the corps (https://cadbim.usace.army.mil/CAD).
The AEC CAD Standard Release 4.0 is set up for AutoCAD and Microstation, so when we work in Revit, the sheets are exported and renamed to follow the standard. However, the the layer properties do not match the standard.
Is there a way to export using a new standard not prepackaged in Revit? Would really be interested in this for future projects.
Thanks!
There have been some changes to the DWG export functions in Revit since this question was originally posted. You can find information for altering/creating standards for DWG exports from revit at the Revit wikihelp.
