Not sure why you want a gutter on a sloped fascia? But. it's possible with
an in-place family sweep, but not with the Roof Edge tools.
Multi-unit development, meaning separate buildings on a site, or meaning
separate units assembled to make a building? If separate buildings, then
separate files, linked together into the site plan. If multi-units, then
one building all in one file.
You can make a tapered column using a Blend. Or you can check sources such
as www.revitcity.com
"Chris Kendall" wrote in message
news:5014610@discussion.autodesk.com...
Hi All.
I have only been using Revit for 2 months and just have a couple of
questions to ask.
- How do you put a gutter onto a sloped fascia, IS IT POSSIBLE?
- When doing a project of multi unit development how do you guys (and girls)
go about setting it up, ie. do you draw all the units in the on project or
do you draw them in there on different project. ( hope that made sense)
- Does anyone know where I can get a tapered column from.
Thankyou Chris Kendall.
