7.0 when?
6 REPLIES 6
132 Views, 6 Replies
7.0 when?
At AU I was told to not install Build Number: 20041113_2030 and wait for the next build due to a memory leak problem. When is the next build going to be released? David
6 REPLIES 6
David, As I understand, the memory leak was fixed with the build you mentioned, but does exist in earlier builds. Maybe they said not to install an earlier one than 20041113_2030? You should be safe with that one. Hope that helps, Danny Polkinhorn WATG Honolulu David Allen wrote: > At AU I was told to not install Build Number: 20041113_2030 and wait for the next build due to a memory leak problem. > When is the next build going to be released? > > David
MamboWarrior
Does anyone have any clue when 7.0 will be released officially? We installed the 7.0 version over 6.2 and all our projects are in 7.0 now. Problem: 7.0 can't be registered yet, and the trail periods is over... Which means we can't open the drawings in 6.2..... all projects are down till official release!!! Is there a trick?
The CD's are expected to ship monday "MamboWarrior" wrote in message news:18211698.1102675873611.JavaMail.jive@jiveforum1.autodesk.com... > Does anyone have any clue when 7.0 will be released officially? We installed the 7.0 version over 6.2 and all our projects are in 7.0 now. Problem: 7.0 can't be registered yet, and the trail periods is over... Which means we can't open the drawings in 6.2..... all projects are down till official release!!! Is there a trick?
Contact Revit support directly and they can help you temporarily re-authorize your copy of 7.0 David Kingham wrote: > The CD's are expected to ship monday > > > "MamboWarrior" wrote in message > news:18211698.1102675873611.JavaMail.jive@jiveforum1.autodesk.com... > >>Does anyone have any clue when 7.0 will be released officially? We > > installed the 7.0 version over 6.2 and all our projects are in 7.0 now. > Problem: 7.0 can't be registered yet, and the trail periods is over... > Which means we can't open the drawings in 6.2..... all projects are down > till official release!!! Is there a trick? > >
what the downloadable 7.0 is no good? I put in my serial and it installed Architectural Staff |>Contact Revit support directly and they can help you temporarily |>re-authorize your copy of 7.0 |> |>David Kingham wrote: |>> The CD's are expected to ship monday |>> |>> |>> "MamboWarrior" wrote in message |>> news:18211698.1102675873611.JavaMail.jive@jiveforum1.autodesk.com... |>> |>>>Does anyone have any clue when 7.0 will be released officially? We |>> |>> installed the 7.0 version over 6.2 and all our projects are in 7.0 now. |>> Problem: 7.0 can't be registered yet, and the trail periods is over... |>> Which means we can't open the drawings in 6.2..... all projects are down |>> till official release!!! Is there a trick? |>> |>> David
Why would they put so many users in this situation? Why not give it a 90 day limit instead of pressing the luck for a 60 day? *shakes head* Architectural Staff wrote: > Contact Revit support directly and they can help you temporarily > re-authorize your copy of 7.0 > > David Kingham wrote: > >> The CD's are expected to ship monday >> >> >> "MamboWarrior" wrote in message >> news:18211698.1102675873611.JavaMail.jive@jiveforum1.autodesk.com... >> >>> Does anyone have any clue when 7.0 will be released officially? We >> >> >> installed the 7.0 version over 6.2 and all our projects are in 7.0 now. >> Problem: 7.0 can't be registered yet, and the trail periods is over... >> Which means we can't open the drawings in 6.2..... all projects are down >> till official release!!! Is there a trick? >> >> >
