David,
As I understand, the memory leak was fixed with the build you mentioned,
but does exist in earlier builds. Maybe they said not to install an
earlier one than 20041113_2030? You should be safe with that one.
Hope that helps,
Danny Polkinhorn
WATG
Honolulu
David Allen wrote:
> At AU I was told to not install Build Number: 20041113_2030 and wait for the next build due to a memory leak problem.
> When is the next build going to be released?
> David
