3D CAD export from Revit 2013
5 REPLIES 5
705 Views, 5 Replies
I am new to revit and having trouble exporting a 3d view of my revit file to cad.  Need to export for client who has revit 2012, any suggestions?
5 REPLIES 5
CoreyDaun
Welcome to the Discussion Groups!
Export from a 3D View to obtain a 3D AutoCAD file. While you are choosing the file location for the export, you can specify the AutoCAD version via the pull-down menu towards the bottom of the dialog.
in reply to: CoreyDaun
I have done that step, the issue i am having is the entire file is not exporting. Not sure if I am missing a step in the process that is causing this to happen.
TAHnk you for the help, much appreciated.
CoreyDaun
Create a single 3D View that shows all of the elements in the Model, and then export from there in order to get the entire model exported. If a Category or Element is hidden, it will not appear in the export.
If the above doesn't help, what elements are not exporting?
Thank you very much for your help and quick response.
So I created a 3D view and turned everything on in the view, I exported again and I get a few pieces of the facades and columns with one floor plate.  Everything else does not show up when I open the cad file.  Thoughts on a remedy?
