2d grid bubbles
2 REPLIES 2
599 Views, 2 Replies
2d grid bubbles
Hello
I was wondering if anyone had a work around, for converting all grid bubbles from 3d to 2d, or setting a default so that when you create grid bubbles they are created as 2d. as i am spending so much time having to click on every bubble to change it.
The reason i am changing them is that if I leave them as 3d then when i stretch a bubble in one view it moves the bubbles in all other views as well
many thanks James
2 REPLIES 2
LisaDrago
Have you used the Propagate extents? When you have selected the gridline - in the ribbon it should have the Propagate Extents button - a dialog box will appear and you can select the view you want it to show up in.
That is the quickest way to adjust them all (that I know of).
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
Thanks for that Lisa will try that
