I'm having a problem installing Revit 2015. The first time I installed I got the message, "The path you have specified for the default family template is invalid". I did some digging around on the Internet and it appears that the content is missing. I uninstalled AutoCAD and reinstalled and still had the same problem. Next I tried using the Autodesk "Uninstall Tool" to uninstalled. I reinstalled and carefully made sure that the content was configured to be installed... and I saw this:
Revit appeared to install correctly because I didn't get any error messages but STILL the same problem! Can I manually download the content and install it myself? How do I get past this?
James
Never mind. I see this is already being discussed here: http://forums.autodesk.com/t5/Revit-Architecture/Revit-2015-Family-Template-File-location/td-p/49575....
James
