in 2012 I was able to have filled regions with a model pattern. In 14 the bubble to change the cut fill pattern is greyed out. I need to be able to rotate a pattern so i need a model one. Anyone else encountering this?
Model type is indeed disabled in cut patterns, you can create one drafting pattern same as model pattern by importing the .Pat file with type=drafting as the changed code. check this link for the detailed procedureof creating it.http://aectrainer.com/?p=171
Hope it helps.
