2013 railings
2 REPLIES 2
russ.green
1808 Views, 2 Replies
2013 railings
I was just experimenting with the 2013 railings to make some stair handrails and noticed a few things.
Working on a dogleg stair with a central spine wall I've placed a wall mounted railing on wall side of the stair.
The railing on the upper flight does not appear in section view. I undertsand this is a know bug.but the other thing is the botton handrail extension turn into the wall and the handrail does not fillet correctly in plan view.
handrails1.PNG.
Is there a workaround to this?
Handrail type settings...
Russ Green
2 REPLIES 2
rosskirby
in reply to: russ.green
Try changing the view from coarse to medium or fine.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
russ.green
in reply to: rosskirby
Makes no difference.  I've put in a subscripotion support request.  will report findings....
Russ Green
