Revit Architecture
jkunkel
Message 1 of 2 (2,721 Views)
2013 Worksharing Monitor Addin File - Where Is It?
2721 Views, 1 Replies
08-30-2012 08:24 AM
I have a user that is getting an error when he opens 2013 that says "Failed to initialize the add-in "Worksharing Monitor" because the assembly "[TARGETDIR]WorkSharingCommand.dll" does not exist".  So I figured I'd open the addin file and make sure it was pointed to the right path.
The Workshare Monitor files are installed properly to Program Files(x86), but i cannot find the addin file.  I can find the addin file for 2011 and 2012, but nowhere can I find it for 2013.  I searched on my PC as well, and no luck.
Where is this file living?
Product Support
Chris.Aquino
Message 2 of 2 (2,689 Views)
Re: 2013 Worksharing Monitor Addin File - Where Is It?
09-04-2012 01:18 PM in reply to: jkunkel
I would check the appropriate location below:
Windows XP:  C:\Documents and Settings\All Users\Application Data\Autodesk\Revit\Addins\2013\
Windows 7: C:\ProgramData\Autodesk\Revit\Addins\2013\
If it's not there, I would try repairing the installation of the Worksharing Monitor through the Control Panel. If the issue continues, I would copy a working version of the add-in file from a working machine to the one that is not.
Chris Aquino
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
The Revit Clinic
@Revitclinic
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
