I have a project with multiple revit files linked in to it. Some of the linked 3D views contain section boxes that section off each floor of the building. (3D-Level 1, 3D-Level 2, etc.)
When I link one of the 3D views and enable section boxes (via the Extents->Section Box and via Overrides -> Links -> Display Settings -> Annotation), a section box will appear, but it is not the same size as the one in the linked file.. which makes my drawing show all of the floors instead of just Level 1. I am able to resize the box manually so I assume it is a local one.
Is there something I forgot to toggle? If not, is there an easy way to figure out the elevation/dimensions of selection boxes in the linked file so I can transfer the data to the local section boxes?
Thank you!
Solved by CoreyDaun. Go to Solution.
I don't believe that you're missing anything (unless I'm missing it too!), in that Section Boxes and Crop Regions do not accompany a Linked 3D View. Under the Visibility/Graphics for the Linked Project, the Section Box Category is not even present. A method of accomplishing this hasn't come to mind, yet...
Shoot. Setting them up manually it is then.
P.S. I think I owe you a beer or something, as you've answered all of my questions so far 😃 Thanks again.
Ah, don't worry - I've already got one!
Anyway, I'm happy to be of use, but I would rather answer this one with some form of solution rather than a simple "Revit can't do that", so I'm going to look into it a little more when I get a chance.
