2012 crashes when clicking on plan to draw a wall...recently installed Gimp2 image editor. Where is the crash journal located for 2012? Thanks in advance, David
I don't know if it will work for you, but you can try turning off your graphic accelerator. It worked for me, Revit 2012 stopped crashing after I turned the accelerator off. I hope this helps.
bahardman
I found the problem (or it seems) to be with windows 7 nastly little habit of applying compatibily settings to revit in the registry.
Fix (for now) regedit all the way down till I found the file with the revit.exe at the end of the string. I deleted it and it seems to be working fine again. Found this fix on a gaming site blog.
David
