Is this true?
“Model Performance Technical Note (pdf - 1225Kb) – When you leave your desk for lunch, and leave work at the end of the day, did you know you’re supposed to delete your local Revit file each time? If you keep working in the local file day after day rather than creating a new local copy twice a day, you are going to realize a huge performance hit, and cause memory errors. Delete the local copy twice daily, and make sure it’s deleted in Windows Explorer. This is just one reason you’ll want to read the Model Performance Technical Note before you implement Revit or a BIM workflow. The Model Performance Technical Note was written by all three Revit platform PM’s and herein they’ve identified all the weakest links in the process of deploying Revit that companies typically run into, so you can avoid them. “
Posted on
http://inside-the-system.typepad.com/
Justin Schaad
