Yeah, I'm going to try that as well. The client wants 1/4" scale plans of
each individual suite (30) without any dims, tags, etc.
I thought I'd be doing it the hard way....Dup w/Detailing, Crop Region,
Select, Filter, Delete, Filled Region (WhiteOut) and after all that, having
to Print, PDF and try to center the damn thing on letter-size....for each
suite.
Hopefully your method will be quicker and easier.
"Scott Davis" wrote in message
news:5204812@discussion.autodesk.com...
View>New>Callouts? This tool is used specifically for creating Enlarged
Plans.
wrote in message news:5204731@discussion.autodesk.com...
Our typical floor plans are 1/8" but we will also use 1/4" scale plans on
our larger buildings. For example we may show an entire level on an 1/8"
scale plan and then create 3 or so 1/4" scale plans showing the same 1/8"
plan in pieces. Is there an easier way to do this than to create duplicate
views, duplicate text, dimensions etc. I know that you can duplicate with
detailing but is there an easier way?
