Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
supressing warning pop ups
1 REPLY 1
NemKumar
3096 Views, 1 Reply
Hi All,
I am trying to display a cylinder triangulation by modelCurve(line).
When each model curve is created and rendered, I get very annoying
warning popups saying "line is slightly off the axis........".
Here is the code for calculating normal
public static SketchPlane createSketchPlane(Document inDoc, Curve inCurve)
      Plane plane;
      // Linear curves have no "normal" returned by compute derivatives
      if (inCurve is Line)
            XYZ point1 = inCurve.GetEndPoint(0);
            XYZ point2 = inCurve.GetEndPoint(1);
            XYZ tangent = (point2 - point1).Normalize();
            // Vertical line
            if (tangent.IsAlmostEqualTo(XYZ.BasisZ) || tangent.IsAlmostEqualTo(-XYZ.BasisZ))
                   plane = inDoc.Application.Create.NewPlane(XYZ.BasisX, point1);
            // Non-vertical line, use cross product with vertical to generate normal vector
            else
                   XYZ yVector = tangent.CrossProduct(XYZ.BasisZ).Normalize();
                   plane = inDoc.Application.Create.NewPlane(tangent, yVector, point1);
       // Non-linear curve supplies normal for sketch plane
       else
             XYZ point = inCurve.Evaluate(0, true);
             Transform transform = inCurve.ComputeDerivatives(0, true);
             XYZ normal = transform.BasisZ;
             plane = inDoc.Application.Create.NewPlane(normal, point);
       return inDoc.Create.NewSketchPlane(plane);
Also I tried to suppress warning by using this class
public class WarningSwallower : IFailuresPreprocessor
        public FailureProcessingResult PreprocessFailures(FailuresAccessor a)
                // inside event handler, get all warnings
               IList<FailureMessageAccessor> failures = a.GetFailureMessages();
               foreach (FailureMessageAccessor f in failures)
                     FailureDefinitionId id = f.GetFailureDefinitionId();
                     if (BuiltInFailures.RoomFailures.RoomNotEnclosed == id)
                     a.DeleteWarning(f);
                return FailureProcessingResult.Continue;
and use this class as in
public static void setFailureDialogSuppressor(Transaction tranasaction)
         FailureHandlingOptions failOpt = tranasaction.GetFailureHandlingOptions();
         failOpt.SetFailuresPreprocessor(new WarningSwallower());
         tranasaction.SetFailureHandlingOptions(failOpt);
and i make call it after
using (Transaction trans = new Transaction(mRevitDoc.Document))
       trans.Start("create Triangles");
       CFRevitGraphicsUtility.setFailureDialogSuppressor(trans);
       trans.Commit()
I need to fix this urgently as I dont have much time left.
I am not able to figure out what am I missing or doing wrong.
As I am creating 100s of cylinders, it popsup for 100s of times.
I dont know how to disable or suppress it.
OR fix the warning itself.
solution for either of the problem will be helpful.
Thanks in Advance.
Tags (1)
1 REPLY 1
R.van.den.Bor
in reply to: NemKumar
And what If you change your warning swallower to :
FailureSeverity failureSeverity = a.GetSeverity();
if (failureSeverity == FailureSeverity.Warning)   //simply catch all warnings, so you don't have to find out what warning is causing the message to pop up
a.DeleteWarning(f);
else
return FailureProcessingResult.ProceedWithRollBack;
Kind regards,
Remy van den Bor
ICN Solutions B.V.
Liked this post or found it usefull, don't forget the Kudo It won't hurt (at least not me).
Rail Community
