Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
"System Data" element
3 REPLIES 3
michele.verda
379 Views, 3 Replies
What is an element named System Data?
I find a lot of this element of Autodesk.Revit.DB.Element type in every project.
They seem empty, no parameters, no level, no phase, ...nothing.
Any idea?
3 REPLIES 3
dear michele,
i never noticed that ... sounds like Revit MEP to me ... could these be referring to MEP systems?
i would suggest starting a new project, using RevitLookup to check whether there are any such elements in there, hopefully no, then adding a new MEP system, checking again, and hopefully seeing one appear now.
best regards
jeremy
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Hi Jeremy,
I've found these element in a RAC project, not in MEP. They are present also in new projects.
Some of these System Data elements are close to phase-type elements and have consecutive IDs.
dear michele,
well, then i don't know what they might be, and i would suggest that you not worry about them either.
best regards
jeremy
Jeremy Tammik
Jeremy Tammik
The Building Coder
Autodesk DevCon in Munich May 28-29th
Rail Community
