Revit API
Active Member
phanmanhquyet
Message 1 of 2 (214 Views)
"Duplicate" 3D view
214 Views, 1 Replies
09-29-2012 06:30 PM
Im using Revit 2012, from my understand, revit api will not allow to duplicate a view. I try to walk a round by create one origin 3D view, then set the properities of new view same as origin, for instance such as: . CropBox or .SectionBox.
But i'm struggeling at how to set the view orientation exactly same as origin view. I have try but not successful. Does anyone know how to solve this?
Thanks.
Quyet
ADN Support Specialist
augusto.goncalves
Message 2 of 2 (195 Views)
Re: "Duplicate" 3D view
10-04-2012 10:50 AM in reply to: phanmanhquyet
Not sure if I'm following, but the View3d object on 2012 API have two relevant methods: eyeposition and sectionbox. Below is a sample from the help file, please take a look.
private void Getinfo_View3D(View3D view3D)
    string message = "View3D: ";
    // The position of the camera.
    XYZ eyePosition = view3D.EyePosition;
    message += "\nCamera position: (" + eyePosition.X + ", " +
                eyePosition.Y + ", " + eyePosition.Z + ")";
    // Identifies whether this is a perspective view.
    if (view3D.IsPerspective)
        message += "\nThe view is a perspective.";
    // The section box of the 3D view cuts the model by its bounds.
    BoundingBoxXYZ sectionBox = view3D.SectionBox;
    XYZ max = sectionBox.Max; //Maximum coordinates (upper-right-front corner of the box).
    XYZ min = sectionBox.Min; //Minimum coordinates (lower-left-rear corner of the box).
    message += "\nSection Box: ";
    message += "\nMaximum coordinates: (" + max.X + ", " + max.Y + ", " + max.Z + ")";
    message += "\nMinimum coordinates: (" + min.X + ", " + min.Y + ", " + min.Z + ")";
    TaskDialog.Show("Revit",message);
Hope this help, please let me know if it doesn't.
Augusto Goncalves
Autodesk Developer Network
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
