Don't believe it's possible I would also like to save current extents, center point & zoom for the current view to re-use on another level which would put the user in the same spot.
I simply want to Zoom Fit in the current active view. Seems simple but again I can't find the answer. Any takers? Thanks Dale
You could try this worked for what I needed a while ago now... http://forums.augi.com/showthread.php?106364-lower-amp-upper-bounds-of-the-current-window-view
Imports AC_App = Autodesk.AutoCAD.ApplicationServices.Application Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Interop Public Class FloorSurferView Private pMax As Point3d Private pMin As Point3d Public Sub New() SaveView() End Sub Private Sub SaveView() Dim ed As Editor = AC_App.DocumentManager.MdiActiveDocument.Editor Using acView As ViewTableRecord = ed.GetCurrentView() Dim pCenter As Point3d = New Point3d(acView.CenterPoint.X, acView.CenterPoint.Y, 0) pMin = New Point3d(pCenter.X - (acView.Width / 2), pCenter.Y - (acView.Height / 2), 0) pMax = New Point3d(pCenter.X + (acView.Width / 2), pCenter.Y + (acView.Height / 2), 0) End Using End Sub Public Sub Zoom() Dim app As AcadApplication = CType(Application.AcadApplication, AcadApplication) Dim lower() As Double = New Double() {pMin.X, pMin.Y, pMin.Z} Dim upper() As Double = New Double() {pMax.X, pMax.Y, pMax.Z} app.ZoomWindow(lower, upper) End Sub End Class
Thanks for the reply, but I need this for Revit (2013). Regards, Dale
Hey guys,
you seem to have missed my last post:
http://thebuildingcoder.typepad.com/blog/2012/06/uiview-and-windows-device-coordinates.html
The UIView class provides full support for pan and zoom. That is what it is there for, as far as I can tell.
Best regards,
Jeremy
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
