Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
objCategoryNameMapIterator Erase Collection is Read only Purge line styles
5 REPLIES 5
david_rock
477 Views, 5 Replies
I'm trying to write a program to erase imported line styles, however I get Collection is Read only from the following code.
Any help appretiated or any work arounds?
<Autodesk.Revit.Attributes.
Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)> _
Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)> _
Journaling(Autodesk.Revit.Attributes.JournalingMode.NoCommandData)> _
Public
Class PurgeLineSubCategories
Implements Autodesk.Revit.UI.IExternalCommand
PublicFunction Execute(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData, _
ByRef message AsString, ByVal elements As Autodesk.Revit.DB.ElementSet) _
As Autodesk.Revit.UI.ResultImplements Autodesk.Revit.UI.IExternalCommand.Execute
Dim lineCat As Autodesk.Revit.DB.Categories
Dim docActiveDoc AsDocument = commandData.Application.ActiveUIDocument.Document
Dim trans As New Autodesk.Revit.DB.Transaction(docActiveDoc)
If trans.Start("PurgeLineSubCategories") = Autodesk.Revit.DB.TransactionStatus.Started Then
If docActiveDoc.IsModifiable = FalseThen
                MsgBox(
"Active document '" & docActiveDoc.PathName.ToString() & "' is not modifiable...")
Else
                lineCat = commandData.Application.ActiveUIDocument.Document.Settings.Categories
ForEach objCategory AsCategoryIn lineCat
If objCategory.CanAddSubcategory Then
Dim objCategoryNameMap As Autodesk.Revit.DB.CategoryNameMap = objCategory.SubCategories
Dim objCategoryNameMapIterator As Autodesk.Revit.DB.CategoryNameMapIterator = objCategoryNameMap.ForwardIterator
                        objCategoryNameMapIterator.Reset()
Dim strKey AsString = ""
Do While objCategoryNameMapIterator.MoveNext
Try
Dim objSubCategory AsCategory = objCategoryNameMapIterator.Current
If objSubCategory.Name = "Enter new name here"Then
                                    strKey = objCategoryNameMapIterator.Key
                                    MsgBox(objSubCategory.Name)
                                    objCategoryNameMap.Erase(objCategoryNameMapIterator.Key)
EndIf
Catch ex AsException
                                MsgBox(ex.Message)
EndTry
Loop
Try
                            objCategoryNameMap.Erase(strKey)
                            MsgBox(ex.Message)
EndTry
EndIf
Next
EndIf
EndIf
EndFunction
End
Class
5 REPLIES 5
jeremytammik
in reply to: david_rock
Dear David,
You are being a bad boy. Erasing during iteration. Tsk, tsk.
I would suggest that you just make a note of the elements you would like to delete within the loop 'Do While objCategoryNameMapIterator.MoveNext', for instance by adding them to some collection of your own.
Once the iteration has terminated, you can delete them all in a separate step.
I hope this helps.
Cheers, Jeremy.
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
david_rock
in reply to: jeremytammik
Hello Jeremy,
Thank you for your reply.
I did thin of that and tried it woithout any luck, I also tried outside the For Each, but with no luck :-(..
Any other ideas?
Regards
David
I now have.
Public
ClassPurgeLineSubCategories
Dim trans AsNewTransaction(docActiveDoc)
If trans.Start("PurgeLineSubCategories") = TransactionStatus.Started Then
                MsgBox(
Else
Dim lineCat AsCategories = docActiveDoc.Settings.Categories
If objCategory.Name = "Lines"Then
Dim objCategoryNameMap AsCategoryNameMap = objCategory.SubCategories
Dim objCategoryNameMapIterator AsCategoryNameMapIterator = objCategoryNameMap.ForwardIterator
DoWhile objCategoryNameMapIterator.MoveNext
If objCategoryNameMapIterator.Key = "Enter new name here"Then
EndIf
Loop
                        objCategoryNameMapIterator.Dispose()
If (Not strKey = "") Then
Try
                                MsgBox(
"Erasing " & objCategory.Name & " " & strKey)
                                MsgBox(ex.Message)
EndTry
EndIf
EndIf
Next
Try
                    lineCat.Erase(strKey)
                    MsgBox(ex.Message)
EndTry
                trans.Commit()
EndIf
EndIf
EndFunction
End
Class
jeremytammik
Hi David,
Good for you. Nope, sorry, no oither ideas, off-hand, I'm afraid.
Cheers, Jeremy.
Jeremy Tammik
The Building Coder
jeremytammik
Maybe this solution can help?
http://thebuildingcoder.typepad.com/blog/2012/10/deleting-a-graphicstyle-element.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
jeremytammik
I just implemented a new external command in The Building Coder samples for this:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Rail Community
