Revit API
New Member
Message 1 of 2 (193 Views)
Accepted Solution
dwg import to 3rd party applications
193 Views, 1 Replies
09-24-2012 01:18 AM
I'm pretty new here so sorry for possibly a very dumb question: what is the best way to read the content of a .dwg file (generated from Revit or any other Autodesk SW) in a my own application? Is the RealDWG only possible solution or does Revit API (AutoCAD API, etc.) provide this kind of functionality as well? I'm kind of confused whether the APIs are only for Autodesk plugins or if they may be used in non-Autodesk apps...
Message 2 of 2 (184 Views)
Re: dwg import to 3rd party applications
09-24-2012 04:40 PM in reply to: tomasvomacka
The APIs extends the functionality of Autodesk products, so they are supposed to be used with Autodesk products, instead of independant applications.
But you can certainly write an exporter using the APIs to export the DWG into your own application.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
