Unjoin Lines
Unjoin Lines
sankar_g
Message 1 of 14
Unjoin Lines
sankar_g
    In revit API, Is there any method to unjoin the lines(Model or detail lines) same as DisallowWallJoinAtEnd() method or any other.
sangsen
Replies (13)
Message 2 of 14
jeremytammik
Dear Sangsen,
No, I am not aware of any such possibility.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 14
bxw
For model lines, I believe if you change one of the lines to a different workset it will cause it to be Unjoined.  Then you  could move it back to the original workset.
Message 4 of 14
Ning_Zhou
lines can be joined? did i miss something simple? i assume lines are elements not geometry.
Message 5 of 14
sankar_g
     Please find the attached images. When I trying to move one rect line it also affects the other rect lines. I want to stop this behaviour for the rect lines only. Can any one suggest me the solution or workaround to acheive this.
sangsen
Message 6 of 14
Ning_Zhou
ic, 2nd to Jeremy, looks like different workset won't solve it or i missed something?
Message 7 of 14
jeremytammik
Dear Bxw,
Can you demonstrate this in detail, preferrably in code?
Thank you!
Cheers, Jeremy.
Jeremy Tammik
The Building Coder
Message 8 of 14
ana_claudia_nilsson
Community Visitor
Community Visitor
I don't know if revit has the command "Explode", have you tried?
Message 9 of 14
That is exactly the function to use.  Hotkey is X
Message 10 of 14
aignatovich
Hi all!
I've tried to do it several years ago without success, and nowadays it looks, that there is also unavailable neither from UI or API.
@sankar_g, please add this to Revit Ideas, may be there will be enough votes ;-). In addendum it will be good, to say to Revit do not automatically join lines on creation via API
@Ning_Zhou, yes, lines can be joined:
Message 11 of 14
Mustafa.Salaheldin
Actually there is a work around.
  1. First select all the joined lines that you want to move then convert them in 2D plan into Detail Lines.
  2. Move these lines wherever you want.
  3. Convert them back to Model line.
  4. Enjoy
If this reply satisfies your need please mark it as an answer. If you struggle with the code just ping me and I can help.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 12 of 14
aignatovich
It doesn't work, at least in Revit 2018.2. After converting them back they will join again.
The workaround can be moving, shorten or lengthen lines to make a gap between lines, but in this case you don't need to convert them to detail lines, just call SetGeometryCurve with overrideJoins set to true
Message 13 of 14
Ning_Zhou
that's typical case of Revit being "over-smart"! default should be always "dumb" instead of "smart", do wish factory can have global settings and let user decide if need auto-join whether it's wall/floor/roof or simple line, or at least exposed in API
Message 14 of 14
Why doesn't Revit incorporate options for user wishes like this which makes complete sense.  Others include using shift key for both adding and deselecting versus control and shift, and cut and paste pdf and autocad integration?  These suggestions has been asked many versions ago
